Old 04-01-2011, 07:13 PM   #1
rjSupra
rjSupra's Avatar
rjSupra is on a distinguished road
Default Is my TPS toast? Bad throttle position sensor - causing lousy power / bad starts?
Dunno why, a just in case I guess, but I just ohm and volt metered my TPS (Throttle Position Sensor).
Pulled cabled connector to TPS. Connected 15 VDC setting on voltmeter to TPS unit / car side (not electrical wire side).
Here's my findings on 2 tests:
My 7M GTE motor has a pin config like this starting at top going down to oil pan floor direction (got this right?? - from TSRM)
VC
VTA
IDL
E2
All measurements made with key ignition switch 'ON' but motor off / cold and not running. It's 40 degrees F here today and not been started in 2 days.
Ohm meter RX100 setting, zeroed dial to '0' with probes connected together at start.
IDL - E2 throttle fully closed = 0 (supposed to be less than 2.3 ohm)
IDL - E2 WOT = infinity (supposed to be infinity)
VC - E2 = 60 ohms (SUPPOSED TO BE 3.9 - 9.0 ohms) - NG
VTA - E2 throttle fully closed = 5 ohms (supposed to be 0.47 - 6.1 ohm)
VTA - E2 WOT = 35 ohms (SUPPOSED TO BE 3.1 - 12.1 ohm) - NG
2nd test
diagnostic box. My diagnostic box does not list a "TT" connector but has a labelled 'ECT' - that the one I used, voltmeter at 15 VDC setting red probe to 'ECT' pin and neg/blk probe to 'E1' pin.
Ignition switch still at 'ON'. Engine off / not running. Car Battery checked in at 12 Volts (it's cold today).
no throttle:
ECT - E1 reading = 4 Volts
WOT:
ECT - E1 reading = SAME - 4 Volts, it did not budge at all.
Crap, did not measure clearance between lever and stop screw. i remember there is fair amount of slack on the two throttle cables before they would engage anything. Will try to re- check this now.
I am not throwing any engine codes (just AT ones) and no code 41 present. I also have insulation exposed on 1 wire to AFM, the Green - Red one. The wire is exposed about 1/4" near AFM. It's not in contact with anything else, but I just noticed this right now (can't really short anywhere that I can think, other cables with it are intact).
So, is this a smoking gun that my TPS is bad? Or something else like a relay somewhere bad? All the fuses were good not that long ago, can re-check them.
As noted earlier, this car has so little power. It idles immediately at 600 rpms always at cold and warm start up (some start problems in very cold weather where it cranks but won't run over), there is never a high idle no matter how cold she is, or how cold outside. Idles reliably, can't drive for shit cold (will barely move on the flats in any gear), after full Op temp on engine temp gauge it can drive down the road. Can drive at 70 - 75 mph, it's very happy at 70 mph and has some power and runs smooth. Runs like shit at 50 - 55mph at 1700 - 2200 rpms (AT in OD), motor runs ok, but no power, and some light stumbling felt and body quiver. Also started bogging down if I give it 1/4 throttle or more at red light start. I wind up accelerating quite slowly pissing off all behind me. I can tromp it and get the Turbo to whine and spool up and I get a lot more power, but not sports car fast power.
Also, I can work with voltmeters no problem. Never ohm-ed a thing in my life so could have been doing it wrong, but seems pretty simple. Can get '1' on certain metal things etc... makes sense to me.
Any thoughts my helpful forum people? Thank you.
88 Supra 7M-GTE Turbo, TEMS, Targa stock
rjSupra is offline   Reply With Quote
