Old 04-01-2011, 06:46 PM   #11
Originally Posted by ochowdero View Post
ok i will,
other than that option, is there any other drive shafts i can use?
No. The only other option would be finding a drive shaft with a compatible yoke so a drive shaft shop could cut that off and use it to build a new one.... they can probably get a new yoke anyway though so it's not worth the trouble of finding a used one (and thus a used U joint). The yoke from another W series transmission such as the common W54 may fit too.
Have you tried local salvage yards? Generally the N/A MKIII isn't very uncommon and the drive shaft is a low demand used part from it.
