Old 03-31-2011, 12:25 AM   #1
The stock setup is complete garbage and should be discarded.... It only flows a small percentage of the oil and has no temperature regulation whatsoever. The cooler is there to cool the system, in a decent system the thermostat is to prevent over cooling. As mentioned the only flow control is the pressure valve. I very strongly recommend replacing the complete system with a full flow thermostatically regulated system when possible.
