Old 03-30-2011, 04:09 PM   #1
My88isGREAT
My88isGREAT's Avatar
My88isGREAT is on a distinguished road
Originally Posted by 91supradude View Post
im not just trying to make the noise thats what i have a BOV for lol.. umm what im trying to do is run the turbo open for more air and also i like the look of it. im running a 30r turbo right now but there is so much pluming and i just want to take out some of it but i have to remove the AFM or whatever its call and relocate it by the throttle body
Stop looking at the open turbos in the Import Tuner mag's thinking these are actual road driven cars... Plus you say there is "so much pluming." Ok, if you have a 7m (assuming you do being a 91 unless you have a jz swap then I am not as knowledgeable) it runs the idle speed controller, factory blow off valve, and positive crank case ventilation... and that is not very much... there are different things you can do with the positive crank case ventilation I have seen and know some about but have not attempted yet. last words, AIR FILTERS ARE MADE FORE A REASON.
My88isGREAT is offline   Reply With Quote
