Old 03-29-2011, 05:37 AM   #1
El_supracabra
El_supracabra is on a distinguished road
Thanks a lot guys! that is a bit of a relief about my timing. Ill still keep it in mind though...
so far i have Ohm tested the TPS (tested good but needs adjusted), the ISC valve, the MAF, the primary coil, igniter, all 3 pickup coils, the fuel pump relay (for S&G's) and voltage tested all of my VSV's. Im thinking that i may need to replace my fuel injectors or replace my ECU....
86.5 Supra NA: milled head .020, decked block .007, .5mm+ pistons, port & polished intake manifold and cyl head,OBX header, 3-angle, cold air intake, Cometic MLS HG. ALL NATURAL!
CHEVROLET- Cracked Heads, Every Valve Rattles, Oil Leaks Every Time
FORD- Flipped Over, Rebuilt Dodge
DODGE- Dirty Old Dust Gathering Engine
I'd rather drive a Toyota, than push a ford.
El_supracabra is offline   Reply With Quote
