Old 03-25-2011, 01:21 AM   #24
GettaRobo
GettaRobo is on a distinguished road
Funny you should revive this thread. I actually managed to fix the problem. What it ended up being were the injectors. I had a donor supra, so I swapped out the injectors and voila, problem was solved. My theory was that they were injectors for a turbo model in my NA model. I don't know if this will help you, but I would definitely check to see if the electrical resistance on your injectors are consistent for your model.
GettaRobo is offline   Reply With Quote
