Old 03-24-2011, 10:21 PM   #23
El_supracabra
El_supracabra is on a distinguished road
Default ancient thread, i know.
I had been having this prob since i bought my supra. I tried the tune-up (dist cap, rotor button, wires, plugs), changed the gear oil in the tranny and rear diff., tested the igntion coil/module, and changed the oxygen sensor.
Then, i blew a head gasket.
After rebuilding the engine (pressure tested the head/cleaned/crack tested block/milled/decked/bore/hone/new pistons/ground crank/re-bushed rods/new bearings/metal Headgasket/arp studs/ port & polish/ new clutch/ new headers/ replaced EVERY vacuum line on the ENTIRE engine/ fuel filter/ cleaned injectors/ cleaned fuel rail/ new air filter/ OHM tested fuel pump relay/ igniter/ coil/TPS/ and all 3 pick up coils)
dropped in the engine. SAME PROBLEM!!!!!!!!! W.T.F!?
Next is ECU. idk what else to do either. I like the idea of replacing the mass air flow sensor.
86.5 Supra NA: milled head .020, decked block .007, .5mm+ pistons, port & polished intake manifold and cyl head,OBX header, 3-angle, cold air intake, Cometic MLS HG. ALL NATURAL!
CHEVROLET- Cracked Heads, Every Valve Rattles, Oil Leaks Every Time
FORD- Flipped Over, Rebuilt Dodge
DODGE- Dirty Old Dust Gathering Engine
I'd rather drive a Toyota, than push a ford.
El_supracabra is offline   Reply With Quote
