Old 03-23-2011, 07:27 PM   #1
El_supracabra
El_supracabra is on a distinguished road
I dropped the tranny last night, there were gouges in the inside of the bellhousing and scratches on the high points of the pressure plate.
I laid the "turbo only" flywheel on top of my OEM non-turbo flywheel and they were EXACTLY the same diameter and no of teeth.
when i laid them side by side the "turbo only" flywheel was about 3/8 to a 1/2" thicker than the OEM non turbo. this was the obvious problem. I had my OEM flywheel resurfaced and i will be putting it back on today. all things permitting.
86.5 Supra NA: milled head .020, decked block .007, .5mm+ pistons, port & polished intake manifold and cyl head,OBX header, 3-angle, cold air intake, Cometic MLS HG. ALL NATURAL!
CHEVROLET- Cracked Heads, Every Valve Rattles, Oil Leaks Every Time
FORD- Flipped Over, Rebuilt Dodge
DODGE- Dirty Old Dust Gathering Engine
I'd rather drive a Toyota, than push a ford.
El_supracabra is offline   Reply With Quote
