Update: The battery would start the car but as time went by it acted like it wouldn't hold a charge. I swapped the battery out and it improved the cars performance. I suppose I could have had a bad cell. The cruise is still not working, I sometimes can adjust the steering wheel and it will work. Any thoughts there? The idle still slowly climbs to 1200rpm after blipping the throttle. Today I will remove all the intake components and check the TPS and ISC. Can all the TPS settings be done off the car? It is running better all the time.
1986 Supra 3.0 NA Stock
5 Spd. Lexus rims 16 x 7
