Thread: Valve Clearance
Old 09-28-2005, 05:42 PM   #1
monkihead
SP58GT
monkihead's Avatar
did you have to deck the block?? the stock thickness is .057in for the head gasket (1.2mm).
if you have a true straight edge and feeler gauge you can check yourself if it needs to be cut. if it doesnt, the valves should clear.
monique- better off dead
