Old 03-16-2011, 11:01 PM   #2
Travis89Turbo
Travis89Turbo's Avatar
Ouch! please tell me you used assembly lube?
Did u clean injectors before they were installed? i had a set of venom that one stuck open and filled the cylinder up with fuel! Pull the other two plugs and see if by chance some dirt or something stuck open the injector. It only takes one cylinder to hydro lock an engine!
Have u tried moving it both directions? I'm not saying rotate your engine the opposite direction for a whole rotation. Just see if it moves at all either way!
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
