Old 03-11-2011, 02:50 AM   #1
"T" it off of the vacuum line which runs to the cruise control actuator (it comes from a vacuum port on the back of the intake plenum. Put the "T" in as close to that vacuum source as possible... the hose T's in a couple places. If you're not using the stock boost gauge you may just use the vacuum line which runs to the gauge's sensor by the cruise control actuator.
