Old 03-07-2011, 10:47 AM   #1
boostindoo
boostindoo is on a distinguished road
Originally Posted by Travis89Turbo View Post
Just noticed you said u have a 90 so no custom mounts needed. Direct drop in. Except for your fire wall needs to be tapped in about 1/2 inch for rear turbo.
i believe the firewall needs tapped in only if he is doin a 2jz....he could also use a turbo lsd rear differential....correct me if im wrong, but with a 1jz swap, u could drill a hole through the firewall under the speedo, send the wire harness through there and flip the ecu so that the plugs are on the leftside...
boostindoo is offline   Reply With Quote
