Old 03-06-2011, 09:15 AM   #20
ochowdero
Huh? From the slave to the fork? The slave it directly in contact with the fork... there's no hose there. It's a simple hydraulic, the only hose runs from the master cylinder (whose piston is connected to the clutch pedal arm) to the slave cylinder which is bolted to the bell housing (whose piston pushes the fork). The line runs from the master as a hard line which then connects to a soft line for the run from the firewall to the slave cylinder... So it's half and half. :P
I thought you had already ordered the hose?
sorry i missed this post ha,
no i didnt order it i pulled it off a car..
like i posted back to btwilson, when i looked at the slave i just figured someone pulled the line before i did..
that good to know, i just hope i get all the parts needed, even the small ones..
im hoping to do the swap next weekish...
1987 supra, BLUE 7mge.. AUTO TO MANUAL SWAP..
i really want turbo
