03-03-2011, 10:42 PM
#31
AEM EMS
Originally Posted by cre
How many types? Two... polyurethane and the OEM butyl rubber. If you're looking for a smooth squeak free ride I recommend sticking with the OEM bushings. The "poly" bushings are not very forgiving and (even when frequently lubed) prone to creaking or squeaking. The poly bushings are a popular choice for people looking for a VERY ridgid and compliant ride. Do bear in mind that with OEM bushings and upgrades elsewhere in the suspension you can still have the compliance but more comfort on less ideal roads.
For a track only car though, poly is the only way to go.
The OEM bushings are probably available individually from a Toyota dealer or any n umber of online dealers of Toyota parts; I do not know if there is any aftermarket manufacturer. Poly bushings are available from most Supra specialized shops; I think horsepowerfreaks.com sells them in a complete kit or individually.... they should be able to get you the OEM type as well.
I don’t think I can add to cre post, but if you do go for poly bushes, I can recommend george@raptorracing.com many UK owners have bought poly bushes from Raptor Racing with good results. Product Link
Energy Suspension MK3 Front End Bushing Set
Price:$59.50
Part Number: ES-MK3-17527
Front Part List:
4- 2749 Upper Control Arm Bushings
4- 2748 Lower Control Arm Bushings
(Rear Facing Position)
4- 2747 Lower Control Arm Bushings
(Front Facing Position)
4 -15.10.602.39 Upper Control Arm Sleeves
4- 15.10.413.39 Lower Control Arm Sleeves
1- 17521 Instruction Sheet
4- 9.11108 Grease (Different quantity supplied with master kit)
(0.812"O.D x 0.562" I.D x 1.945"L)
(1.000"O.D x 0.640" I.D x 2.950"L)
Front install instructions:
Energy Suspension MK3 Rear End Bushings Set
Price: $89.50
Part Number: ES-MK3-17522
Rear Part List:
8- 2752 Upper Control Arm Bushings
4- 2753 Lateral Link Bushings
4- 2754 Rear Toe Link Bushings
4- 2755 Rear Trailing Link Bushings
4- 2756 Spindle to Trailing Link Bushings
10- 15.10.167.39 (.875"O.D x .562"I.D x 1.960"L)
All Positions except spindle to trailing arm position.
2- 15.10.20.39 (.875"O.D x .562"I.D x 1.800"L)
Spindle to Trailing Arm Position.
1- 17522 Instruction Sheet
Rear install instructions
