Old 02-27-2011, 10:08 PM   #1
Travis89Turbo
Travis89Turbo's Avatar
Here is some of the bracket needing grinded.
Name:	IMAG0221 (640x383).jpg
you also need to grind the bolt down for the ac hose!
Name:	IMAG0230 (640x383) (640x383).jpg
now your ready to drop the motor in!! Haha I wish it was that easy! It is a very tight fit! you have to take the ABS brake line cover off and separate the bottom line and tap it in about a 1/2" as it gets in the way of the back turbo!
Droppin her in! TIGHT FIT.
Name:	IMAG0222 (640x383) (640x383).jpg
Finished pics!
Name:	IMAG0223 (640x383) (640x383).jpg
here is the pics of where you hook up your ac wires! you only need the blue wire you unhook the blue wire out of the chassis plug under fuse box! Rememer when testin this that it has a low pressure switch so if your still out of refridgerant you wont get power to the ac magnet.
Name:	IMAG0238 (383x640) (383x640).jpg
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
