Old 02-21-2011, 11:45 PM   #2
rjSupra
rjSupra's Avatar
rjSupra is on a distinguished road
Default getting fuel noise in or next to throttle body - so pretty sure getting gas & batt g
I can hear the whoosh of fuel in or next to the throttle body / fuel rail area. I just put the ignition key in and turned to 'on' and then jumped the FP & B+ connections. I could clearly hear fuel then, so I think that part is good.
I have tons of stuff in the car so was not able to verify if the fuel pump under carpet is clicking on ignition key in. Do i still need to check that if I can hear the fuel pumping while I am doing the above bypass?
(also there is that 21 code - Ignitor / ECU and code 14 O2 sensor / ECU happening, so could that shut me down from re-starting?)
and how the heck do you know if it's a bad ECU instead causing problems? Seems like a lot in the error codes, the lower possible culprit is - ECU!
Thanks.
88 Supra 7M-GTE Turbo, TEMS, Targa stock
rjSupra is offline   Reply With Quote
