Old 02-19-2011, 04:13 AM   #5
The Check Engine light should ALWAYS come on when the key is turned to the ON position but not started; If it doesn't the bulb's burned out or there's a fault in the ECU.
If there are no diagnostic codes the Check Engine light will flash continuously at a high speed.
http://www.cygnusx1.net/Supra/TechTi...ror_codes.aspx
