Old 02-17-2011, 01:46 AM   #3
Your car doesn't have a MAF... it has a VAFM and the GTE's have a KVAFM A huge difference between all three.
Check for diagnostic codes; Very few or the error codes will turn on the check engine light.
Fuel pump and filter are possibilities, but there are many others too. Start with checking the codes and post back.
http://www.cygnusx1.net/Supra/TechTi...ror_codes.aspx
Here'e the info on testing the VAFM (you may refer to it as an AFM if you like, both types used in the MKIII are AFM type devices).
http://www.cygnusx1.net/Supra/Librar...ection=FI&P=94
