Old 09-26-2005, 05:59 PM   #1
intense 7MGTE
intense 7MGTE is on a distinguished road
Default 30psi and octane
In order to run 30psi of boost you will need a bigger turbo first of all. The stock CT26 can only push out 15psi and at that point it is just blowing hot air. Secondly you will need a stronge top and bottom end wjich you have. Then you will need a tuning computer like a VPC2, a SAFC or better yet a EMS from AEM. Then you will need to run at least 100 octane to keep the motor from blowing sky high. 91-93 pump gas just will not cut it.
intense 7MGTE is offline   Reply With Quote
