Old 02-16-2011, 08:15 AM   #1
ahruizguerra
ahruizguerra is on a distinguished road
Suggestions:
  1. Check the MAF sensor connector. Sometimes it looks like it is hoop up right; but inside terminals might be dirty.
  2. Check The TPS connector
  3. Check the IDLE valve connector, do you hear any sound out of the idle valve as soon as you turn off your car????
  4. Check that the fuel pressure regulator and fuel pump are working correctly.
Do you have the check engine light on????
ahruizguerra is offline   Reply With Quote
