Old 02-13-2011, 10:45 PM   #1
Break you post up into paragraphs please. It makes it easier to sort through.
First. The code 52 is a critical code. If that's present the ECU will DUMP a lot of extra fuel in and pull a lot of timing advance. You need to take care of that FIRST. Do a search on the forum for knock sensor rewire and make sure they're both actually present and connected (there are two sensors on the GTE block, only one on a N/A).
The next codes to look at are the coolant temp and the O2.
The stalling, crap drive-ability and difficult starting cannot be looked into any further until at least the coolant and knock codes are fixed; The knock code is the worst of them all.
