Old 02-13-2011, 07:37 AM   #1
itsjustsway
itsjustsway is on a distinguished road
Regarding the oil hose lines... I didn't even think to qualify my recommendation. Are you looking to upgrade the hoses for the stock cooler setup? If so, you're wasting your money... save up and upgrade to a full flow cooler using the larger hose sizes I suggested. I'll look to see if I can find a writeup. The parts needed are: Cooler (1'x1') or so, remote mount filter adapter, remote mount filter head, oil cooler thermostat, hose. All should be 1/2" and 1/2" NPT or AN-10... that's the size of the hose and fittings.
The stock hose is metric, I think the stock hoses are small, only about 8 or 9mm.
I wanted 2 get a braided oil line for the turbo..I pulled the motor 2 do somethings nd the oil line leading is a hard muthaf 2 put bak LOL .. I thought this could work with a new intercooler set up
itsjustsway is offline   Reply With Quote
