Old 02-11-2011, 10:47 PM   #2
Travis89Turbo
Travis89Turbo's Avatar
Wink
Originally Posted by bbullsj View Post
so i should find a turbo 5 speed and find a 5 speed harness. i assume i will need to find a harness for a 5 speed that also has the turbo and abs connectors on it? or is the abs unit part of a different harness?
I would def. recommend an r154 but it is gonna cost you more money. But money well spent, cuz how good is a great engine without bein able to put it to the ground. The clutches for r154 last a lot better for higher HP.
If you use an automatic ecu. You HAVE to use an automatic harness that's the only way you can trick the ecu.
There is a few wires in the engine harness that are used for ABS. But like i said earlier your abs won't work on jdm trannys without buying the sensor.
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
