Old 02-11-2011, 07:26 PM   #1
Travis89Turbo
Travis89Turbo's Avatar
You can trick it if you use another auto harness. But then you have more wiring then needs to be there with a 5 speed. The plug to jump is next to the starter! The w58 (NA trans) will work but you have to use a na clutch with turbo flywheel. Which you will be way over powering a stock na clutch so id recommend upgrading.. stay away from ebay clutchs.. The r154 (turbo) trans is alot more robust and reliable under higher HP. But it uses a pull style clutch not a push type like the w58.
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
