Old 02-08-2011, 09:51 PM   #1
907mge
907mge's Avatar
If you are staying na then don't waste you money. The hg s went bad due to too low of torque and not the gasket. I believe the factory gasket with proper torque is good to 12 psi on the 7mgte. Not to mention most went bad when the car wasn't covered used warranty anymore. Plus the gaskets are the same for ge and gte. I personally used felpro with arp studs and have been doing good now for a few thousand so far.
