Old 02-08-2011, 12:15 AM   #1
El_supracabra
El_supracabra is on a distinguished road
well, i called the machine shop. My machinist "had never heard of this happening before" and has milled "hundreds of blocks, with this style timing cover". *rolls eyes*
So instead of completely tearing down my freshly rebuilt engine, i have decided to remove the head, loosen the bolts in the timing cover and "re-center" the timing cover on the seals. Then i used the step down measurement of a dial caliper to determine how much my timing cover was off. It measured EXACTLY .015" (i measured it 3 times) , well my machinist claims he only took .007" off the deck. Im not buying it.
so i am just taking my timing cover in, and having it milled down by .015"
do you think i should replace the front main and oil pump shaft seals? *they were new before I torqued the head down, but were slightly distorted by forcing the timing cover down*
86.5 Supra NA: milled head .020, decked block .007, .5mm+ pistons, port & polished intake manifold and cyl head,OBX header, 3-angle, cold air intake, Cometic MLS HG. ALL NATURAL!
CHEVROLET- Cracked Heads, Every Valve Rattles, Oil Leaks Every Time
FORD- Flipped Over, Rebuilt Dodge
DODGE- Dirty Old Dust Gathering Engine
I'd rather drive a Toyota, than push a ford.
El_supracabra is offline   Reply With Quote
