Old 01-19-2011, 02:44 AM   #1
Busted Knuckles
Busted Knuckles's Avatar
Probably just tighten it down. It could be the wiper arm loose, or the motor's hold-down bolt may be working itself loose.
I had mine torn down recently, and the hold-down nut is under a few things. First, remove the wiper arm, then loosen and remove the first big nut under the arm. This will let you take the metal dome cover off and expose the actual hold-down nut. Then, you can tighten it.
I sanded and spot-filled the rust pits on my dome cover and wiper arm, and gave both a nice few coats of Ultra Flat Black. I was lucky that the dome cover had no rust-thru spots. The hold-down nut was nice, clean, and rust-free, thanks to a good seal all these years with that dome cover.
