Old 01-12-2011, 03:53 PM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by itarumaa View Post
Hi,
hope you are having a good day. Now I can find all sorts of info about how much hp to get from Supra, but I cannot find anything related to service of the car.
I am considering to buy a Supra 3.0l NA manual, from year 1994.
But what kind of service intervals does the car have?
1. When does the timing belt need to be changed? How many miles or years is the interval. Should the timing belt pulleys and tensioner be changed as well. Does the timing belt run the water pump as well and should that be changed when timing belt is done?
2. What is the service intervals for serpentine belt and does it pulleys need to be changed with the belt?
3. What is the recommend coolant and brake fluid change intervals? Does the car have normal Dot 4 fluid for brakes or something more special?
4. Oil and filter change, recommended values and what is the normal oil used in the car? 10w40 or something else?
5. Are spark plugs basic stuff or some high tech ones that you can only get from Toyota with serious price? And what interval those have
Any this kind of information would be nice to have, since I would like to know more about the car and what kind of service it does require.
Thank you in advance and have a nice day
If you're buying a "Supra 3.0l NA manual", you should also buy the Supra 3.0l NA owner's manual, Toyota part number 00400-14507. It will answer all of these questions.
Disclaimer: If this post doesn't help, please ignore it. Please don't shoot the messenger! I have an Mkiv TT, not an N/A, so I don't have the answers to your questions myself. In other words, by recommending that you purchase the owner's manual, I've pointed you to the only source I know to provide you with a complete and 100% accurate answer to all of the questions you asked.
P.S. Did you at least like my play on the word "manual"?
Life begins at 30psi.
