Old 01-12-2011, 02:20 AM   #1
2JZDU
2JZDU is on a distinguished road
Did you fix it yourself? Also, did you (or the mechanic) determine why the cam sensors were failing when it was cold?
I tool it to mechanic, cause I couldn't find any diagnosis tool around.
they didn't tell me when you found the code, but I guess the code which they found should be stored in ECU. casue They did they in the morning, and it's not cold.
but I srtill don't understand, what relation between cam sensor and cold weather....
2JZDU is offline   Reply With Quote
