Thread: Oil seal
Old 09-24-2005, 08:51 PM   #1
hangsupra
Smile
there is two type of differntial for the mk2 supra. one is for the LSD n the other is non LSD. look on your vin # under the hook where the axle codes are. there sure be something like this. xxx.xxxx.(xxxx).xxxx. (last # on the ( )axle code) if the last digit in the axle code is a 3 or a 5 then your differential are a LSD. that i know that its a diff. differential tho. double check n buy again. hope this work. correct me if i wrong peoople.
