Old 01-04-2011, 05:06 AM   #1
jprezwodek
jprezwodek is on a distinguished road
Exclamation Wha-What??
A v6 can be installed into the MK3 pretty easily. Its a small engine lengthwise compared to the stock 7M (or 1J in later models), and the engine bay is more than wide enough for almost anything. If you are comfortable with some fabrication, you could build a motor mount. That would be the easiest thing, and least expensive. If you aren't good with the physical work, but can make the design, draw it up and send it to your local shop. it can be done in a few days.
If you don't have a clue where to start, maybe someone here will have an existing mount plan that you can use.
Before you take on dropping in this motor, what are you planning? Serious performance, or daily driver?
Personally, a V6 won't give you the kind of performance an Inline 6 will when it comes to tuning. The mustang engines are great, but don't make very reliable horsepower in my opinion. (Compared stage for stage with a 7M)
They are more prone to having a blown engine in the long run than a 7M with a properly torqued head gasket...
What are you planning for this car?
-Jeremy
MK3 - 1988 Turbo (7M-GTE)
5 Speed
Cruise Control
Targa Top
Kicker and Pioneer Stereo Mix
Brand New Engine (ATK Remanufactured)
Iridium Plugs
Mobil-1 Synthetic
CT-26 Turbo (Being Rebuilt)
Non-TEMS Sport Shocks
jprezwodek is offline   Reply With Quote
