You don't need an upgraded pump for this mod, the stock one flows more than enough. You DO need to be 100% sure yours is in good shape (so might as well replace it with a better one anyway). As mkiiisupra said, you must install the injectors first or prior to the AFM or you will run lean at WOT.
