Thread: ABS Problem?
Old 12-13-2010, 06:28 PM   #1
btwilson86
Super Moderator
btwilson86's Avatar
Disconnecting the ABS computer will just leave you with standard brakes. So if your problem is a faulty ABS component, then this will likely be ok. If the problem is with the caliper, as the tech suggested, then disconnecting the ABS computer will not benefit you in any way
