Thread: 11lb flywheel
Old 12-12-2010, 05:12 PM   #1
89ST
89ST is on a distinguished road
the weight itself is not going to be bad for your engine or anything?! That is a significant weight reduction over the stock flywheel. You'll really notice the difference in first and second gear. the car will climb through the same rpm range a lot quicker. Therefore you're acceleration will be quicker. It will also cause a slightly lesser load on the engine so you might not build as much boost in first. I'd say its a good upgrade though
89ST is offline   Reply With Quote
