Thread: Starting issue
Old 12-12-2010, 02:56 PM   #10
Bru
Bone Stock w Upgrades ;-)
Bru's Avatar
The oil seal repair kit won't fix a wiring issue. You can test the wiring / pickups with an ohm meter. Hack the wiring or get a replacement. The problem could be on the harness side of the wiring or the plug connection.
here is a eBay search
http://motors.shop.ebay.com/i.html?_...506.m270.l1313
Here is the CPS plug Ohm readings.
http://www.cygnusx1.net/Supra/Librar...ion=IG&Page=16
You can use an aligator clip to connect to G- and one of the three +. wiggle the wire bundle and watch if the needle drops intermitently indicating a break inside the insulation (analog ohm meter). Test all three + wires. Look inside the the harness side of the plug to see if any of the grip clips are stretched open too far. Adjust if necessary.
