Old 12-10-2010, 07:05 AM   #1
Originally Posted by xAimz View Post
7mgte is soposed to be at 12deg stock
7mge is 10
That's what you should see at a warm idle on each setup (roughly).... they're both still set to 10 when you're setting the timing.
http://www.cygnusx1.net/Supra/Librar...aspx?S=IG&P=20
Did you check for diagnostic codes? Test the AFM? Are you sure it's going lean?
