Old 11-27-2010, 04:58 PM   #2
Busted Knuckles
Busted Knuckles's Avatar
Default It sure sounds like a bad bearing.
Did you check for looseness at the rear diff and the pinion shaft? The pinion shaft is where the driveshaft connects to the rear differential. I've seen these go bad and create the bearing noises you hear.
