Old 11-22-2010, 04:03 PM   #1
Anthonyhuynh3
Anthonyhuynh3's Avatar
Anthonyhuynh3 is on a distinguished road
Will you do the work yourself? Parts will probably cost $4000 or more. You need the engine, complete harness, ecu, ignitor, resistor pack, downpipe, and other items I'm not aware of. Labor for someone else to do the work will be about $1K I'd guess.
Be sure to get a leakdown & compression test on the engine before you buy it. Also be sure you have someone evaluate the leakdown & compression numbers who understands compression and leakdown tests, and is very familiar with both brand-new and used 2jz-gte engines.
thank for your tip , i will try find some 1 near me can run the test on the engine before i buy it.
if some 1 here ever done a swap gte-and r154 please give me some more hint thank
Anthonyhuynh3 is offline   Reply With Quote
