Old 11-21-2010, 03:55 AM   #1
Green7mgte
Supra Forum Moderator
think you should bleed your brakes.. then take it around the block and see what happens. check your fuild level. does your brake light come on when you brake quickly from speeds above 35? if so its probably low fluid.
squishy brake pedal is vindictive of air in the lines..
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
