Old 11-17-2010, 06:37 AM   #1
Jackalope501
Jackalope501's Avatar
Jackalope501 is on a distinguished road
Use and cleaning for wool pads:
One of the next products you'll need for your wool pads is a buffer spur.
This is what you use to clean your wool pads while you're buffing. You can pick one up for about $5.oo-6.oo USD, so there's no excuse for stabbing the pad with a screwdriver to clean it out. This is a quick way to destroy some pads, and downright dangerous. Watch how fast a wool pad spinning at 3000 rpm on a high-torque motor can sling something, and you'll understand.
Your buffer spur is also essential to breaking in a new pad when you buy it. You can't use them right out of the box or you, your car, and everything nearby will look like a chia pet. The yarn on a new pad is very thick and fluffy, and it will throw copius amounts of fuzz everywhere. you'll need to wash and spur the pad several times before you can buff with it.
Spurring the pad:
Place the buffer against your leg with the pad facing away from you. With your machine set at 3000 rpm, pull the trigger and place the spur against the face of the pad so the wheels spin with the pad itself. This should basically look like the needle arm on a record player, for those of you old enough to remember what they looked like. Run your spur across the pad face from inside to outside edge until the pad stops throwing dust. Your pad will get gummed up with your polishing products while you use it, so you'll do this several times while buffing a car. Now you know how it's done...
You can wash your pads in the washing machine on the gentle cycle with normal detergent, but it has a tendency to warp them. A warped pad doesn't stay on the backing plate very well. For this reason, I hand wash pads in the driveway. Use your hose, a stiff brush and a bucket of soapy water. Dunk the pad, scrub it and rinse it well. Repeat a few times when breaking in a new pad. Let's say you've buffed with it already on a red car. Now your white wool pad is pink. Spray it down while it's still dry with your 50/50 degreaser mix, then wash it.
Drying pads is the fun part, cause they hold a lot of water. Start by tossing the pad (wool side up) like a frisbee up and down your driveway. This knocks out excess water. Do this until it quits leaving wet rings on the pavement. Now attach it back onto your buffer and spur the pad to remove the remaining water. Yes, you'll get a little wet doing this...suck it up. Once the pad stops misting, set it out in the sun to finish drying. On a warm day this should only take about an hour. This is why you want to have at least 2 of each pad type you use.
NEVER put a buffer pad in the dryer...EVER.
Jackalope501 is offline   Reply With Quote
