Old 11-17-2010, 05:47 AM   #1
Jackalope501
Jackalope501's Avatar
Jackalope501 is on a distinguished road
Let's move on to pad selection...
There are several varieties available, but we'll start by breaking it down into two groups. Wool and foam pads.
Wool Pads:
These are agressive cutting pads. You will hear me use the terms "hard" or "soft" pads. This refers to their cutting power, or abrasive levels. How do you tell the difference? By color. Your most aggressive pad is a white wool pad, shown here with a velcro backing.
This is your most common form of attachment. You will use a 7" rubber backing plate on your machine with the male side of the velcro. These typically come with a new machine. The female velcro side will be on the back of the pad itself. That's hook and loop fastener for you military types. Your white wool pad gives you your best cutting power. That means it removes more oxidation and scratches. For most applications, this is where you start. This is also the pad you will use with heavier compounds.
Next is your yellow wool pad, shown here.
This is a softer wool blend, used as a finish pad. Simply put, this shines more than a white pad does when used with the same products. So let's review...White pad = cut...Yellow pad = shine
Here's a typical kit from buff and shine...probably the best pads you can buy.
This kit comes with a white wool pad, yellow wool pad, a black foam pad and the backing plate for all 3. At $32.oo USD, it's a bargain. I'll add the link here for anybody shopping.
http://www.tooltopia.com/buff-and-sh...n=shopzilla_r1
Jackalope501 is offline   Reply With Quote
