Old 11-16-2010, 12:22 AM   #1
Killa B
Killa B's Avatar
Killa B is on a distinguished road
Exclamation
Originally Posted by Sonyps307 View Post
Flywheel
Clutch
Clutch and brake pedals
Master and slave cylinder
Lines between master and slave
Shifter
Front part of the drive shaft
And u have to do something to some switch Can't remember
And the clutch is a hydraulic one there is no cables
I think i have a list of the parts please post for confirmation.
clutch pedal
brake pedal
clutch master cylinder
manual drive shaft
manual gearbox
manual bell housing to fit my engine
clutch kit to suit my gearbox
clutch line to go between mater and slave cylinder
driveshaft and prop
clutch officer cylinder?
clutch enslaved cylinder
pilot bushing
shifter, inner and outer boot
starter interlock switch
flywheel
also since my car is a non turbo can i use and r154 transmission (that tranny only comes in a turbo model correct?) and just switch out the ecu?
1989 na turbo supra ~ 3ARacing exhaust 2.5" pipe no resinator, sports package
Killa B is offline   Reply With Quote
