Old 11-13-2010, 08:17 PM   #1
Moved to the correct section. Now you're likely to get some response.
I'd start with checking for power at the ECU connections: BATT, B+ and B1+ Check grounds too, especially the ones which run to the head and the one from the battery to the block.
