Old 11-08-2010, 10:47 AM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by JDM Supgra View Post
I found where the engine light is located and noticed it does not turn on nor the oil light comes one when you open the ignition, I took that part of the circuit apart and noticed the solder on the connect pins were cracked, so resoldered them and was able to read the codes and I was getting code 42 which is vehicle speed sensor, so I guess I need to replace it.
Cheers,
Rafi
Thank you for posting back here and keeping us updated. Excellent work on your troubleshooting of why you weren't getting any diagnostic codes.
Regarding your speed sensor, note that the signal actually goes through the odometer. It's possible the odometer panel circuit solder joints need to be re-flowed as well.
Life begins at 30psi.
