Old 11-04-2010, 04:58 PM   #1
MJG
MJG's Avatar
That appears to be one of the "cat back" systems on Ebay. If so, you may wish to check with the vendor and see if this system bolts directly to the DP.
Most of those Ebay systems are intended for "off road use only". The fact that the system includes the muffler insert, which is designed to be used to "quiet" the exhaust on the street and be removed when at the track, suggests it will eliminate the second cat.
As mentioned, without a resonator, it will be loud. If you run the muffler insert, you will find it very restrictive and it will negate the free flow characteristic of the 3" pipe.
The two systems I have seen from Ebay (not the system pictured) are a good value for the cost. Both eliminated the second cat, had resonators, and are loud enough to turn heads under acceleration.
