Old 10-28-2010, 10:38 PM   #14
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by jdmdriver View Post
I was just meaning like new pistons and little stuff like that do you know where i could get a 2jz engine and tranny?
ROFL pistons aren't "little stuff"! This is a 1000hp-capable 3L engine out of a $50K gt sportscar! Bearing tolerances are measured in hundred thousandths of an inch. Unfortunately, your neighbor's cousin bubba really doesn't have the machining tools or the skills needed to build a 2jz-gte.
If Toyota's oem 2jz-gte pistons aren't strong enough for you, just how much horsepower are you planning to make???
Regarding your question, Toyota sells 2jz-gte engines and v160 trannies.
Ok so when i get the motor I should look to get smaller turbos for the twin turbo setup? what brand or what kind of turbos are good for the smaller twin turbo setup?
the oem twin turbo setup already comes with smaller turbos. The brand is Toyota.
Big and mid-sized single turbo kits have several other brands to choose from.
Life begins at 30psi.
