Old 10-28-2010, 01:02 AM   #12
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by jdmdriver View Post
ok I am new to supras I loved them ever since i got to ride in one. Im looking to get the 2jz engine this winter and build it up a little...
"Build it up a little"??? Whatever for? It'll handle 1000hp bone-stock. How much horsepower do you want to make???
...and put it in a car this spring. So i need help finding a motor and tranny first then i need help with the shell. and i also was wondering im seeing alot of people on here say swap the twin turbo system out and put a single turbo kit in i was wondering why and which set up is better?
The oem twin turbo set up is sequential. Two smaller sequential turbos is "better" because it spools up quicker than one bigger turbo. HOWEVER, a single turbo setup is bigger because you have more choices of much larger turbos. There are aftermarket (large) twin setups, but they're mostly parallel (not sequential), so they don't spool up any faster than a single. Also, the aftermarket (large) twin turbo setup is more expensive than a large single turbo kit.
Life begins at 30psi.
