Old 10-24-2010, 04:25 PM   #1
89ST
89ST is on a distinguished road
If you wanna rebuild the bottom end of your 7m then you can go much higher than 500whp. The 7m is a pretty strong engine once you get the hg locked down. Also the single turbo in the end will probably produce more hp, with less problems. and is a lot easier to upgrade/work on.
89ST is offline   Reply With Quote
