Old 10-24-2010, 05:55 AM   #1
cfurlan
cfurlan is on a distinguished road
Well I got the whole engine tore down today. Pulled out Main and rod bearings and they were already shot after 800 miles. Also found the cause to the ticking noise. It was the intake cam not being tightened down all the way. Some of the bolts were backed out so far they were hitting the valve cover. Also got the block primed and painted. Bearings will be in Monday and the gasket set should be in by Tue or Wed. I labeled everything so hopefully I will be able to get it back together. Wish me luck
cfurlan is offline   Reply With Quote
